How much HP with a mechanical fuel pump?
Re: How much HP with a mechanical fuel pump?
the fuel lines on a 600 sc and an 800 sc only have a 1/4 pipe fitting to feed two carbs
my stock 600's dropped fuel pressure with a regular pump added
he is also checking the fuel pressure before the rail right at the pump
i check mine at the end of the fuel rail
the problem is your fuel system will only flow what the smallest restriction is and a single 1/4 pipe fitting will not feed 800 hp
BillR
27
08-10-2008 11:31 PM
