Pressue relief valves? >
Old 08-07-2006, 04:27 PM
  #41
waterbum's Avatar
Default Re: Pressue relief valves?
Is it possible the valve starts to open at 12, but still allows pressure to climb to 20 or so? I thought the stock merc valve started to open at 20 and then fully opened at 30 which some builders think is too high. Like a radiator cap, it doesn't let all of the pressure out at once, but starts to hiss at a certain PSI and lets out more steam as the pressure increases until it reaches full open position.
waterbum is offline
Old 08-07-2006, 10:11 PM
  #42
Rebel_Heart's Avatar
I'm getting mixed reviews. The water pressure at WOT was 12 after the spring had been cut. Several have said that this is too low, while others have said that this shouldn't be concern. I don't want to have the head work in question, but don't want to run excessive pressure either.
Rebel_Heart is offline
Old 08-07-2006, 11:03 PM
  #43
Ginger or Mary Ann?
US1 Fountain's Avatar
You can always put a SS washer for a 3/4" bolt behind the spring to bump the pressure back up a bit if you wish.
WB. When I installed my valves last week, I left the dump hose long and hanging over the side to watch it work. Dry until 25psi. Then the dump volume increased as pressure did. The valve fluttered while controling the pressure by a few lbs. I suppose if the dump hose was just a little smaller, it would give just a bit of restriction on the back side of the relief valve to stabilize it a bit.
US1 Fountain is offline
Old 08-08-2006, 01:03 AM
  #44
Back4More's Avatar
Should have mine Wed.
Back4More is offline
Old 08-08-2006, 01:51 PM
  #45
Back4More's Avatar
They have arrived...Orange stripe spring is out and which springs did you go with out of McMaster Carr?
Old 08-08-2006, 04:21 PM
  #46
Ginger or Mary Ann?
Originally Posted by Back4More
Wish they had more in SS....
They do. 302 SS.
Mine just came in. Look exactly like the original. Was afraid the number of coils might be different.
pt # 1986K18 $11.17 for 6
Old 08-08-2006, 10:26 PM
  #47
Back4More's Avatar
Thanks, Will call pick up in the morning.... I live 2min from them.
Old 08-09-2006, 10:11 AM
  #48
Back4More's Avatar
WOW! They are perfect replacements! Thanks for the direction on those.
Old 08-09-2006, 05:52 PM
  #49
Ginger or Mary Ann?
Keep track of your free spring length and WOT pressure. Just for a comparison of what I end up with. That's my weekend project.
Your welcome
Old 08-09-2006, 10:12 PM
  #50
Back4More's Avatar
I'm thinking they are good to go right out of the bag....I will see Saturday.
Quick Reply: Pressue relief valves?
