oil pan gasket
i did a search and didn't find much info, i need to get a new oil pan gasket and i am not sure if i need a special marine one or if i could just go to napa and get one. its 1990 454 carb 330hp markiv motor with the stock merc pan. thanks for the help--
Save yourself some pain and get the Felpro one piece 1884-R gasket. Its more expensive but soooo much easier to deal with. A little dab of sealer at the corners is all you need.
![Thumbs up](/forums/images/icons/icon14.gif)
Just got through using one. Got them at auto zone for 26.00. Forgot the part number but it was felpro and blue rubber. Only problem I had was the sales woman insisting on a cheaper cross referenced gasket. Obviously not the one I wanted because it was in a flat box. The one peice will be in box about 4 inches thick.
![Talking](/forums/images/icons/icon10.gif)
Yup, the one piece gasket is the way to go. I only use those on the MKIV 2 piece rear main seal motors. Much nicer to use and install. Plus if you ever need to take the pan off you can re-use it again!
John S.
John S.
I tried a one piece felpro, didn't actually fit that well. I ended up having an annoying leak all summer. You may want to go with the MR. Gasket Ultraseal - MRG-5883 on summit racing. It only costs $10 too.
The key is what you use with it though. I highly recommend using "The Right Stuff" gasket maker by Permatex. I've been told you can seal leaks externally with this stuff. It comes in a aerosol can too so it's easy to apply.
That's the current setup I'm using, no issues. Just my 2 pennies though.
