Gen + small block ??'s
Anybody know if the "gen + " ( vortec) 96' and above
shortblock is the same as the 87' -95'
short block ?
short block ?
Re: Gen + small block ??'s
There are some minor differance's but they are interchangeable.The vortec 5.7 are hydrualic roller motors but you can use standard lifters if you want.Since the vortecs don't use a distributor I'm not sure if the cams have drives for one but any aftermarket cam will fit.Also they use a plastic timing chain cover that has studs built in where the dowel pins would normally be in the block but a steel cover will work,just install the dowels.The main thing I ran across is the hole for the fuel pump drive rod is not machined in the block,must use electric pump.All accessories will bolt on.Hope this helps,Magnum.
Thanks,
that's what i was wanting to hear.
I knew the heads are different ( 8 intake bolts )
wasn't positive on the block.
I've got a frozen block project a guys
bringing me ( 2002 5.7 volvo), and I want to have all my
ducks in a row.
ducks in a row.
Rockfish71
4
05-29-2008 01:39 PM
