Gimbal Removal
Charter Member #139 /Moderator/Platinum Member
Gimbal Removal
well yanked the drives today and will remove ghimbals to morow for rebuild
found out today needed a special tool for pivot pin rmoval its cheap from merc but since I want to do this tommorrow I will fab one at work
\bell housing already has the mercury kit installed for removing gimbal while engine is in palce any thing else I should watch for
Snow slowed me down a little today
Re: Gimbal Removal
just had my first glitch I had thought of doing that but these are the hp pins has a threaded hole down the center an two small srews that seem to hold it on my clymer manual just has old style
its part #10 in this view
http://www.mercruiserparts.com/Show_...Steering+Lever
dont know how thwy come out now I was thinking of a bolt down center and pull out but this maks no sence
Re: Gimbal Removal
On my HPs, they come right out after removing the two screws. Be sure to locktight those screws when it goes back together.
B-MAX REPAIR
Re: Gimbal Removal
IF YOUR GIMBAL RINGS ARE WORN OUT AT THE TOP WE CAN FIX THEM. CHECK OUT MY WEB SIGHT AT WWW.JRMARINE.COM WE ALSO MAKE STAINLESS SWIVEL SHAFTS AND STAINLESS U BOLTS THAT WOUN'T STREATCH. RON BENDER CELL 216-390-1330
