What HEADS would you select?  On a 2K budget. >
Old 03-08-2006, 05:54 AM
PatriYacht's Avatar
Default Re: What HEADS would you select? On a 2K budget.
How many rpms are you turning and what speed. Your engine looks like a torque monster on paper. Maybe you should try going up in pitch on the prop. It might be making more power but at a lower or the same rpms.
PatriYacht is offline
Old 03-08-2006, 06:39 AM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Its turning a 24 labbed prop at 4,900. Around 68 GPS
in a Pachanga-22.
1BIGJIM is offline
Old 03-08-2006, 06:57 AM
Pat McPherson's Avatar
Originally Posted by 1BIGJIM
The cam is a COMP 270 Extreme Marine
hyd.flat tappet
544 547 Gross Lift
112 center line
Adv Max RPM 5,800
Personally I think you have selected cam that should make real good power to 5000rpm in your 496 with better flowing heads. The tighter 112° LSA will extend the rpm range vs. the 114° of the 420cam.
With a good set of heads and an intake to match your engine will make a lot more power. Those heads need lots of work and bigger valves to flow.
Is the engine sit in the boat?
Swapping heads and an intake is doable in the boat, a cam change would be a PIA...
Patrick
Pat McPherson is offline
Old 03-08-2006, 06:59 AM
PatriYacht's Avatar
Try a 26. It might pull it to 48-4900 rpm.
Old 03-08-2006, 07:02 AM
I agree, now way those heads flow enough for 4900rpm.
Patrick
Old 03-08-2006, 07:07 AM
Charter Member #927
Payton's Avatar
With a good set of heads and an intake to match your engine will make a lot more power. Those peanut port heads need lots of work to flow.
Crane says the 420 cam is 112* lobe
http://www.cranecams.com/?show=brows...61&lvl=2&prt=5
Payton is offline
Old 03-08-2006, 07:14 AM
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 5 BTDC 43 ABDC 109 228 °
Exhaust 57 BBDC (1) BTDC 119 236 °
Maybe I'm not doing the math right, but I believe 114°LSA
Patrick
Old 03-08-2006, 07:34 AM
MarineKinetics
rmbuilder's Avatar
Pat,
You are correct.
109º ICL
119º ECL
114º LSA
Bob
rmbuilder is offline
Old 03-08-2006, 09:42 AM
With out going to a roller cam
and
my current cam will work,,
Getting back to my original question
What heads would you select?
The engine is in its winter home ENGINE STAND
1BIGJIM is offline
Old 03-08-2006, 09:53 AM
44MTI's Avatar
Personally, I like the Brodix 3x CNC. They have made great power for me and have been recommended by many engine builders.
You might also look at the PRO 1's from Keith Eikert. They are advertised in the classified's for 2k a set complete, I think.
44MTI is offline
Quick Reply: What HEADS would you select? On a 2K budget.
