What HEADS would you select? On a 2K budget.
Re: What HEADS would you select? On a 2K budget.
Originally Posted by 1BIGJIM
Getting back to my original question
What heads would you select?
The engine is in its winter home ENGINE STAND
Patrick
Patrick
My current setup is 454 stroked to 496 CI
781 Large Ovals with original size small valves.
118 CC chambers. With SRP pistons 9:1 compression ratio
Comp Cam Extreme Marine 226/236 @ .050
BG Sea Demon 750 DP
Edelbrock Performer Intake
I do not want to spin this over 5,500 RPMs
Last year after spinning a bearing(long story, stupid mistake) I stroked it to a 496 and only gained 100 RPMs same compressing rato, cam heads etc.
I obviously have a bottle neck somewhere, and I am thinking the heads?
Edelbrock Oval Marine Heads 110CC
290 Intake Runner. What would this raise the compression ratio to?
I am guessing around 9:6.
Dart Iron Eagle. 119CC chambers, 305 Intake runners same size of valves as the Edelbrocks. Probably flows better out of the box. These can be had for about $1,500.
Any other IDEA’s
Thanks in advance for your input, and based on it will determine what I will purchase in the next few days.
BG Sea Demon 750 DP
Any other IDEA’s
The head will work but is not optimum choice. A nice aftermarket 300 CC runner would be a good choice. Low to mid lift airflow on these heads are exceptional so the use of a mild cam would make a nice flat powerband.
Head options would be the Canfield, AFR, Brodix, or the Edelbrock. I would go the route of hard anodizing for longevity.
