TRS Transoms, what is innerchangeable? >
Old 03-14-2006, 11:04 AM
Default TRS Transoms, what is innerchangeable?
I just pulled 2 complete TRS Transoms with rams and inner plates out of storage for a friend. He has #2's. Will any drives other than the TRS fit on this transom/gimbal housing? What about 3's. Thanks.
TxHawk is offline
Old 03-14-2006, 11:47 AM
Charter Member#330
MrCIG's Avatar
Default Re: TRS Transoms, what is innerchangeable?
Only a TRS or a TRS with the speedmaster bottom (AKA #2) will fit on the Trs transom assemblies.
Mark
MrCIG is offline
Old 03-14-2006, 12:02 PM
Konrad
JIMG is offline
Old 03-14-2006, 12:29 PM
Rookie's Avatar
Received 1,281 Likes on 622 Posts
ExcaliburHawk40, sorry for the hi-jack.
do speedmaster lower #2 take a different prop then a TRS? Is there a big benefit having #2's over TRS. (Drive height, nose cone geometry?) what would be a plus. TRS parts are easier to find then #2 parts. are there different nose cones for TRS's, any way to change drive height?
just curious.
On with the regular discussion.
Rookie is offline
Old 03-16-2006, 07:52 PM
Rookie.....Hydromotive Engineering make nose cones for the TRS....Fred.
fred is offline
Old 03-17-2006, 09:01 AM
Rookie,
Forget about IIs, parts are almost non-existant.
They use a different prop, 19 spline speedmaster.
The II is actually longer than a TRS (about 2"). So to gain the benefit, you would have to raise the engine, gimbal, drive.
And what MrCIG said about interchangability.
Gary
rdoactive is offline
Old 03-17-2006, 12:41 PM
Rookie's Avatar
I am now looking into TRS nose cones. I talked to a guy who put them on his 30' predator or coyote or something like that and picked up 2-3mph. (73-76mph) After reading some threads on nose cones the TRS seem to benefit. now just what brand.
Rookie is offline
Old 03-17-2006, 08:06 PM
cuda's Avatar
I was told Imco makes a nosecone for the Trs, but I didn't see it on their website.
cuda is offline
Old 03-18-2006, 02:37 PM
Use the one from Hydromotive Engingeering.
JIMG is offline
Old 03-19-2006, 08:27 AM
FX10's Avatar
I'm pretty shure the Konrad Ace Drive is a direct bolt up to a TRS drive. Or maybe it's the 520..or 540. You can also run a higher X dimention with the Konrad.
FX10 is offline
Quick Reply: TRS Transoms, what is innerchangeable?
