Iron 118cc heads to aluminum 110cc , how much will comp ratio change?
That is what I wanted to hear
I was running the iron heads with 9:1 at 36 degrees of advance.
Just trying to avoid a meltdown
![Evil](/forums/images/smilies/evilB.gif)
![EEK!](/forums/images/smilies/eek.gif)
Found this on the web. Help ya with the math
http://www.kb-silvolite.com/calc.php?action=comp
Originally Posted by 1BIGJIM
I was planning on running the Air-GAP?
Any other ideas?
Any other ideas?
There was a guy here a while back that saw good gains on the dyno switching to the single plane Vector Jr. on those heads.
Patrick
Patrick
yes they were E-brocks. This is not uncommon, more like the norm. The chambers are cast so there will be some variance.
DCR has alot to do with how much static you can run
Originally Posted by racinfever
Big Jim I am running a 540 NA with aluminum heads , compression ratio almost 10.1 40 degrees timing & using 89 octain fuel for 9 years. Motor runs great made 720 hp on dyno. Have built other motors similar even with efi with great success. ![Cool](/forums/images/smilies/cool.gif)
Your wallet, are you saying I could have a possible
MELTDOWN?
MELTDOWN?
