525sc no spark
I bought the boat in Nov, and it started up fine. I tried to start up my motor getting ready for the spring, but now I got no spark. I have current to the ignition module. Unfortunatley I don't have a wiring diagram, what are the colours of the cables connected to the coil and how is the module grounded?
Any advise are appreciated.
Thanks bl
Thanks bl
![Mad](/forums/images/smilies/mad.gif)
to check for sig to the coil; use a test light on the neg side of coil attach other end to batt +, should flash as you crank the mtr
to check for hot from ign switch check for current at coil+ with key on
I had the same thing happen on one of mine after the boat sat for a couple of weeks. It turned out to be the small plug that goes into the ignition module. There was a small amount of corrosion on one of the prongs. Drove me crazy but I found it. It was cheap to fix too
