Bravo ISSUE
Charter Member #927
Re: Bravo ISSUE
You should be easing back on the Thottle as the boat leaves the water, so that your RPMs don't change when your prop breaks free. Then back onto the the thottle as your prop reenters.
I have never had my drive shift into nutral.
Re: Bravo ISSUE
Well, I try to come off the gas in time. But every once in a while they do kind of spin out. I do have rev-limiters on it to save the motors but the outdrive does seem to kick out into neutral. I wounder if it has anything to do with that drive Haven the extra gear in it for the lefthand rotation?
Re: Bravo ISSUE
There is no extra gear. All Bravo's can be run in RH or LH rotation.
So it comes out of gear and you have to come off plane and go to idle and put it back into gear???????
Charter Member #927
Re: Bravo ISSUE
IF that is the case, you need to keep your hand on the thottle and be ready to pull back at any time. And, I would bet if you pull your prop off, you'll find a twisted prop shaft.
