Stronger engine mounts????
I'm running a stock Merc Big Block mount set up with the larger stock type (Thicker castings) OEM mounts lag bolted to the stringers. How much HP will those hold with the stock (but longer) lag bolts? I'm going blown this year with about 800 HP. Last year was 650 with no problems. Not drag racing, mostly top end stuff
Re: Stronger engine mounts????
Monstaa, could you please forward those pics to [email protected] Thanks.
