outdrive for 900 h.p.
Re: outdrive for 900 h.p.
Originally Posted by zt260
For many single engine applications, an extension box causes issues. I wouldn't put that kind of money in to a drive that might work. If you know of someone with the same hull and power with an extension box that works well, I'd consider it. Most everyone has had bad luck with extension boxes on my Checkmate.
What hull is it?
What hull is it?
BMax's new HT is garanteed to 950hp/tq I have been running the Poker run edition for 3 year with good luck. I have the new Ht on order now
Rob
Rob
Rob
Rob
Originally Posted by awesomecat26
are you going to be selling the old one?
Rob
Rob
Rob
Originally Posted by customryder
Hey Rob, I guess you will be uping the boost now
Rob :
if you had to choose a outdrive for a 4500 lb boat with 900 H.P. and ther was no room to use a trans.[the drive must shift ] what would you choose ?
Masher touches my
B-Max's are the shiznit. Wait until you see one in person if you haven't already, they dwarf a regular Bravo style drive. I think the gears are over 5 inches instead of 3. The 4X4 and 1000 are pretty nice too but will need the tranny in the extension box.
