Procharger M1sc on 7.4MPI Help !!
![Unhappy](/forums/images/icons/icon9.gif)
I have my boat at a Mechanic and hes stuck on a few issues this is his first install of a procharger on a boat.He has the install manual from procharger.
ok first does the oil cooler go back on ?? if so where is it relocated?
I have a set of dana headers and looks like they are going to have to manufacture a bracket.
fuel preasure regulator install as well ?
any help would be great [email protected]
![Frown](/forums/images/smilies/frown.gif)
Yes! you need the oil cooler; you may even consider buying a lager one.
Yes! you will need an adjustable fuel pressure regulator to raise the fuel pressure. There are kits to modify the stock regulator. Call AZ Speed, Precision EFI, or Tyler Crockett...
Patrick
Patrick
One other thing, go easy on the timing. The combo of the Vortec heads and cast piston in that engine are a receipt for a melt down...
Happy Boating!
![EEK!](/forums/images/smilies/eek.gif)
Happy Boating!
Patrick
Patrick
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
The regulator to use should have came with the kit.. & yes you need an oil cooler.. Jamie / Lakeside
![Smilie](/forums/images/smilies/smile.gif)
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Originally Posted by snake plissken
Hi Jamie is it relocated? the oil cooler?
Jamie / Lakeside
Thank you guys !! picked up the boat and im taking it to a place who has done these before the guy seemed to know his stuff. will keep you posted thanks once again
