anybody have a diagram of drive trim connections for ssm #3s
a friend of mine disconnected my trim ram hyd lines amd didn't make where they go, and i dont know what goes where now, i have 1979 cig with the original rams and square bottom trim pumps. thx for any help. rm
The lines on the distribution block could have been reversed over the years. So the best way involves trial and error. The pump has a hi and low pressure side, they are not interchangable.
Energize the blue side, this is the trim up, high pressure circuit. hook the high pressure hose up and see if the drive goes up. If not, switch it.
Green is the low pressure, down circuit.
Gary
Gary
The hi-press or up lines are normally the front lines on the block. If you look in the bilge, most riggers will put one or two wire ties on the up lines where they go throught the transom. If you have to you can trace the lines from the pumps. The hi-press. fittings are marked.
rdoactive, the blue green check is what got me sorted out, someone had swapped the lines at the block under the drive. thx, rm
Gald it helped. On old boats, it seems to be a 50:50 chance if they're right.
BTW, if you're hooking up trim tabs, it's the opposite.
Blue, high pressure for down. Green, low pressure for up.
Gary
Gary
gotime34
06-15-2006 09:34 PM
