Ignition Timing
Ignition Timing
What should the stock Merc thunderbolt ignition timing be set at on a 1989 330hp 7.4L. Looking for the most advance without detonation for more hp. Should this be set at Idle with base timing or is it better to rev up the engine and set the timing while it has full advance?
I hate the winter!!
Re: Ignition Timing
With the stock Merc ignition, you are limited as to what you can do. I would set the timing at full advance to 35*. Let the base end up where it wants to.
Re: Ignition Timing
Originally Posted by fbh-velocity
I allready done that, bin there. NO increase at all. Stay at 32* and be on the safe side of detonation.
best wat to go, if you go much more then 34 total you will need to increase octane
