Who makes the best 15" trailer tire?
10x
I've got a triple axel loadmaster trailer under my 10 mtr Fountain. When I purchased it back in 01, it had Carlisle tires on it, size ST 225x75x15, and they say for trailer only, and they are a class D load range, that's about 2450 lbs per tire load capacity, so that's about 5000 lb per axel.
Well, it seems like the threads on all the tires keep seperating because the belts are breaking. I doubt I put more than 1000K miles a year on the trailer, and every year I have to replace atleast 2 tires. These tires don't last 5000K miles without coming apart, hell 3000 miles!!!
It's a real pain in the azz to go to the lake and findout that you have a baseball size blister in a tire when you get to the boat launch. And I only live about 15 miles from the launch, so I don't put that many miles on it each year.
Has anyone else here had problems with Carlisle brand tires? They tell me that the warranty period is only 90 days.
Do you think I'd be better off running a LT type tire, like from a SUV?
The LT tires that I've found in size LT 225x75x15, are only a class C load range.
Don't know if I should keep buying a new tire whenever one goes bad, or scrap all of them and try something else.
The trailer does'nt have alot of tire clearance to the fenders or I would put a bigger tire on it. So I'm limited to keep a smaller diameter tire on it like the 225's. A 235 would probablly work. The tires are radials.
Want some suggestions on what you would do.
Thanks for the help...............Frank
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
[email protected]
![](http://i4.photobucket.com/albums/y137/purple66bu/motorsindaboat.jpg)
Frank,
I have always had great luck with Carlise trailer tires. My boats have been considerable lighter than yours, that I guess would be the difference. I have read alot of guys running the Goodyear Marthons with good luck. My new trailer has these on it so I am going to give them a try,
This is only from I've read. Alot of people have had alot of problems with Carlisles. Alot of people have had good luck with Marathons, although recently I've read people having problems with them as well. Two brands I would look into would be Towmaster and Maxxis. Maxxis can found at Greenball.com. As far as Towmaster do a search. Towmasters came on my latest trailer purchase. i can not vouch for them yet as I've not received my new boat yet, thank you Mr. boat manufacture. Two months late now. I would look into these brands and scrap your current tires and save yourself aggravation. Just a though.
Charter Member #927
I got Goodyear Marathons that are at least 5 years old on my trailer. I tow about 45 miles twice a year. Then about 300 yards from the barn to the ramp.
Toxic FORMULA
I've used Goodyear Marathons for 17 years and have towed thousands of miles over the eastern half of the country with a car carrier and boat trailer and never a problem.
Just keep them property inflated. I also cover them in the winter to protect them from UV rays.
steel 16" trailer wheels are $25 each- go buy 7, and then buy 7 235-85R16E tires which can be bought for under $100, if you shop, around and never look back
10x
That's for all your comments. I'd go with the 16's in a heartbeat, but I don't have the fender clearance for a taller tire.
There is a radius in the fender that goes around the top of each tire, and it seems like they put the axels pretty close together, so a taller tire is out of the question unless I want to do some major revamping to the trailer. I'm gonna look into the Marathons by goodyear.
Thanks for all your input.
Frank
![Mad](/forums/images/smilies/mad.gif)
Frank
[email protected]
[email protected]
carlisles suck. do a search. there was a thread at one point, who got the SHORTEST distance on a carlisle. I think it was 10 miles or so. Ive never had good luck with any of the carlisles i run.
Ive only heard good about the goodyear marathons however.
