Help! Burned piston
#41
SORE MEMBER
1 Post
Re: Help! Burned piston
Originally Posted by scarab39
I wish I could run a mechanical but the motors i have don't have a provision for a pump (mk VI). stupid chevy
Did this on my buddies 560hp BBC, has been reliable for 3 years.
#44
I should have asked here first! I ordered a set of brodix heads from tony barker racing today.
Make sure they are marine friendly
#45
Did ya shop price??
#46
I called Brodix and talked to them about my application, They explained that is would be a special order and had me order through Tony. Tony's making sure I get the right hardware.
#47
Originally Posted by Wobble
Look for the belt drive pump that came with gen 5 motors, these can easily be upgraded with a Carter M61045 mechanical pump from summit. You just switch out the valve body of the carter pump on to the mercruiser pump lever assy. Requires #10 inlet size hose and #8 outlet I believe. No regulator.
