How much to rebuild HP500EFI's >
Old 04-28-2006, 04:29 AM
Off the Radar
Linster's Avatar
Default Re: How much to rebuild HP500EFI's
GOODT,
Not trying to start nothing here, but I was making the point that 15-20K an engine is way to much. File fitting the rings does not take over an hour. That was included in the $500 assembly. I missed an few things that both Rob & you brought out oil etc. OK throw another 1K at it. Still, its not 15K, which was the point this thread was leading someone to.
The price I said was reasonable, was the same you said you can do it for and do it right. Sounds like you charge a reasonable price so that you can make enough to keep the doors open and do a great job. We need more people like you and not the 15-20k vultures. With what I missed I will admit 7K is in line and I was a little too low.
I hope I did not offend any one I just hate to see people get taken to the cleaners when there are great repitable people like you & Mike11 who will do it right for a fair price.
Linster is offline
Old 04-28-2006, 04:41 AM
Off the Radar
Linster's Avatar
Rob,
Just got a set from Flatlander. Heres a price right off the web site.
http://www.flatlanderracing.com/
R10575 502
(4.466 Bore) Plasma Moly Top Ring 2mm 1.5mm 4mm Std. .005 $139 a set from Flatliner
LLH
Linster is offline
Old 04-28-2006, 06:31 AM
Steel Outlawed's Avatar
I just had a complete rebuild done on a 500 efi, and it cost $7,500. That did include two pistons, re-working heads, 2 injectors, then the normal gaskets, roller rockers, and so on.
Steel Outlawed is offline
Old 04-28-2006, 01:25 PM
Rob
Strip Poker 388's Avatar
Originally Posted by Linster
Rob,
R10575 502
LLH
I was thinking they were higher.Never had to buy a set of the metrics before .Linnie You water testing yet?????
Just think Gino Lubejobs just had a top end freshen done for a little less that 15 k for 2 no r&r no valves
Rob
Strip Poker 388 is offline
Old 04-28-2006, 03:23 PM
Semper Fi's Avatar
I am having Joe (GOODT) rebuilding one of my HP500EFI's right now and tuning up the other. He is a straight up, honest guy and gave me straight up excellent, FAIR price in writing--You can't ask for more than that
He was highly reccomended also.
Semper Fi is offline
Old 04-28-2006, 03:52 PM
Charter Member #34
Dock Holiday's Avatar
I did my two 500 EFI's last year with 300 hours and actually could have ran them another season probably. The only issue I found was head gaskets. They were getting thin in a couple of spots.
A friend of mine just pulled his out of a 38 Scarab with 400 hours to do the same thing we did.
Bottom line is we replaced the heads with better flowing heads, all new top end including cam and valve train. New gaskets, new bearings, etc and I have less then $15K in both engines total!
Dock Holiday is offline
Old 04-28-2006, 05:41 PM
Thanks for all the info everybody. Maybe top end is all that is needed. They all run great, but one of them seems to burn a little oil. The motors were probably run 50% idling, 49% cruise (3000-4000 rpm) and 1% wide open.
I have read other threads that say valve springs should be replaced (at least checked) at 200 hours. What kind of life are others getting with these motors?
I'm trying to sell the boat but people are afraid of the hours. I would want to have a deal before actually doing something with them.
innthered is offline
Old 04-29-2006, 07:32 AM
Off the Radar
Linster's Avatar
I would suggest doing the bottom end as well. The GM rings are low tension and tend to burn oil. After 320 hours on mine, the rings crumbled when I removed them. The Speed Pro, Moly file fit with standard tension are a good fit.
Good Luck
Linster is offline
Old 04-30-2006, 06:47 AM
offshoredrillin's Avatar
Received 1,297 Likes on 449 Posts
Jeff at JC performance has my 500 EFI's right now, he is bumping them up a hair and doing some Jeffy and Zul tricks to them. there are a couple other guys on here that he did the same thing to theirs and they LOVE them, give him a call he is an advertiser on here.
offshoredrillin is offline
PhantomChaos
16
01-14-2005 06:39 PM
DIAMONDPERFORMA
5
12-03-2003 07:21 PM
dhlaw
8
08-03-2003 09:47 PM
Dean Ferry
12-03-2002 02:02 AM
diveboy
9
11-03-2002 01:50 PM
Quick Reply: How much to rebuild HP500EFI's
