How much to rebuild HP500EFI's
My 2001 HP500EFI motors have 300 hours on them. I think it may be time to have them freshened up. What can I figure the cost will be to do this? Who can do this?
Re: How much to rebuild HP500EFI's
I think it may be more like 20k as this guy gives low ball estimates and then it's "... guess what we found when we pulled them apart time".....I know a guy who would redo them right for about 25k.
Let me know if you want a hook up.
I will probably pull/reinstall them myself. Is that price "per motor"? I have a triple, as in three of them, to do. Anybody give a quantity discount?
Off the Radar
1 Post
NO more than 6K if things are good.
Hone: $125
Rings $ 175 ( Speed Pro File Fit)
Main Bearings $ 35
Rod Bearings $ 40
Head Gaskets (Cometic) $175
Intake gaskets $ 20
Lifters $500
Pan Gasket $40
Rear Seal $35
Front Seal $ 25
Springs (929) $125
Valve Job & Assembly $225
Surface Heads $ 125
Valve Seals $30
Assembly $600
Pull & Reinstall $500
Exhaust Gakets $125
Misc $ 200
Total $ 3060
Profit $3000 (100%)
Total $6060
15K to 20K is not a good number unless for all three
Hone: $125
Main Bearings $ 35
Rod Bearings $ 40
Intake gaskets $ 20
Lifters $500
Pan Gasket $40
Rear Seal $35
Front Seal $ 25
Springs (929) $125
Surface Heads $ 125
Valve Seals $30
Assembly $600
Exhaust Gakets $125
Misc $ 200
Total $ 3060
Profit $3000 (100%)
Total $6060
Where are you located??? A very capable engine builder is located in Scranton, PA............they are building the new version of my 1965 Daytona Scarabs from scratch for he Ghost Rider............S&L Motors.......old line company, less emphasis on glitter and a lot of savy on the go part.....ask for John Lewis @ 670 342-9718..........Scranton is an old line place, S&L prices are also old line..........
Geronimo36
300 hours and need rebuild already? were the run hard or poorly maintained? How about just the heads if bottom end is solid
Chris G.
Chris G.
linster, your close but off by about 2000 file to fit rings extra labor not included, r&r is low should be about 850 and you didnt include dressing the mtr and stripping it, and assy if done right (check and double check) is alittle low
the labor #s are about right for a 5.7 even jasper gets 2500 for a 5.7 and I wouldnt put it in my worst enemys boat
If I build someones 500 I make sure its not going to come apart, will I do a complete rebuild and R&R for 6000 no because it means short cuts where taken
oh and just noticed do you replace lifters, springs ect and not replace the cam
real simple and I think most builders/ tech will agree do it right or dont do it at all
No I am not the cheapest... but it will be right
If you want cheaper call me and Ill be more then happy to point you to cheaper and tell you how many Ive had to go back into because someone was "cheaper"
Hone: $125
Main Bearings $ 35
Rod Bearings $ 40
Intake gaskets $ 20
Lifters $500
Pan Gasket $40
Rear Seal $35
Front Seal $ 25
Springs (929) $125
Surface Heads $ 125
Valve Seals $30
Assembly $600
Exhaust Gaskets $125
Misc $ 200
Total $ 3060
Profit $3000 (100%)
Total $6060
Hone: $125
Main Bearings $ 35
Rod Bearings $ 40
Intake gaskets $ 20
Lifters $500
Pan Gasket $40
Rear Seal $35
Front Seal $ 25
Springs (929) $125
Surface Heads $ 125
Valve Seals $30
Assembly $600
Misc $ 200
Total $ 3060
Profit $3000 (100%)
Total $6060
Linnie Are the metric rings 175.00????
other stuff..............
oil pump and pick up
impeller kit ,
out drive oil
aligned engine
R&R drive?
SQ deck block?
thermostat kit
fuel filter, both
oil and filter twice for break in
Sp plug wires
cap and rotor
also like Goodt said higher on R&R especially on trips,,10 hr each
also most Ive seen charge for dressing
also you can by the felpro kit with the good gaskets,except the metal head gaskets ,, a cheaper in the kit???
Maybe guides???
maybe exhaust valves ???
With out seeing seeing the condition of everything but assuming nothing major. A complete rebuild with dyno run would be around 6-7k ea.
If we can help let me know.
Thanks Mike
Roccard Marine Engines
[email protected]
www.roccardmarineengines.com
570-956-2840
Thanks Mike
[email protected]
570-956-2840
