Stainless Steel hardware on a Cast Iron Block >
Old 05-03-2006, 06:45 PM
pachangalpina's Avatar
Default Re: Stainless Steel hardware on a Cast Iron Block
what are the Merc oil and power steering coolers that are attached to the block made of?
pachangalpina is offline
Old 05-03-2006, 07:41 PM
waybomb's Avatar
Originally Posted by jmherbert
Townsend Engineering.... I guess I should say Stork Townsend these days. I mainly work with our sausage co-extrusion (QX) machines. Who do you work for? I know we have a $hi% ton of skinners and other equipment there.
And I am in the same line of work - Cher-Make sausage and we have your machines. Not QX, but linkers.
formula31 - I sent an email to Mo today to order another airshearz. Tell him to read his emails!
waybomb is offline
Old 05-03-2006, 07:57 PM
formula31's Avatar
hehe, you dont really think Moe is computer literate do you? LOL Just kidding, but I do think he fought it for a while.
formula31 is offline
Old 05-03-2006, 08:56 PM
GOODT's Avatar
[QUOTE=pachangalpina]I said it would help :rolleyesQUOTE]
wasnt trying to put any one down, Im just tired of trying to take things apart that had anti sieze on them.... trust me its a pain, the only thing I hate more is being upside down drilling out exaust manifold bolts on big block factory manifolds ( trust me it sucks)
just got done drilling out 32 bolts upside down, and yes I have turbo sockets and every easyout known to man
GOODT is offline
Old 05-03-2006, 09:50 PM
MOP
Try the site below they can supply any grade including ARP and licensed ARP in any size or type you need, every external bolt, nut, washer and more that is on my stroker they supplied. I was a marine mech for over 30 years don't let anyone talk you out of S/S, just don't buy junk good S/S will never let you down.
http://totallystainless.net/totally.html
Phil
MOP is offline
Old 05-03-2006, 10:33 PM
GOODT's Avatar
Phil
words of wisdom, head them..........
very true
oh and for my sake please dont use anti sieze
GOODT is offline
Old 05-03-2006, 11:26 PM
MOP
I have had very good results using non hardening gasket compound instaed of anti sieze, I also use clear silicone on bolts and nuts that I want to stay put. I have always worked on salt water boats the trick with getting things apart down the road is to keep moisture out of the threads.
Phil
MOP is offline
Old 05-04-2006, 09:05 AM
I called Totally Stainless this morning. Had everything I needed but would take me a couple weeks to get. I will look around here locally as I want to start assembling this weekend.
About the clear silicone, I was under the impression it did not like aluminum. My Intakes are aluminum. Could I use the red permatex?
Thanks for the input.
Island Time is offline
Old 05-04-2006, 10:43 AM
Ok, I missed it! What is the problem in using anti seize???
blownboat is offline
Old 05-04-2006, 12:48 PM
Sounds like the anti seize actually worked more like loctite.
Quick Reply: Stainless Steel hardware on a Cast Iron Block
