merc 525SC's >
merc 525SC's
merc 525SC's
Old 05-06-2006, 11:44 PM
Neno the mind boggler
glassdave's Avatar
Default Re: merc 525SC's
are the 525's based on the 454 or 502?
08 OPA High Points Champion
glassdave is offline
Old 05-06-2006, 11:46 PM
454
Rippem is offline
Old 05-07-2006, 12:04 PM
customtouch's Avatar
I had one in my 26' Scarab. I bought it used from a guy that ran the piss out of it! I also ran the piss out of it for three seasons with no problems before selling the boat! I have been looking for a pair to put in my 29', so if you don't get them let me know! They are not much faster than the HP500 but the bling factor of a (dependable) blower motor is worth it to me!!!
customtouch is offline
Old 05-07-2006, 12:32 PM
DRIPPINWETII's Avatar
Great motors
Attached Thumbnails merc 525SC's-cleland-engines-001-small-.jpg   merc 525SC's-cleland-engines-002.jpg
DRIPPINWETII is offline
Old 05-07-2006, 03:08 PM
good engines... ck for small blower pullies.
customryder is offline
Old 05-08-2006, 06:54 PM
glassdave's Avatar
Originally Posted by customtouch
. . . . the bling factor of a (dependable) blower motor is worth it to me!!! . . .
kinda what i was thinking, there nice and whiny to
good info guys.
Old 05-08-2006, 11:46 PM
Received 1,967 Likes on 988 Posts
My 525sc has been great and pretty much trouble free. I went through the top end at 350 hrs and all still looked real good. I changed to roller cam(731), replaced the springs, and a got a valve job.
I just fired mine yesterday for the first time in 7 months. It took about 5 seconds to fire up.
Do a search on 525sc. Lots of good info.
Griff is offline
Old 05-09-2006, 06:37 PM
Had the pleasure of running a pair of 525 SC's for 7 years. Changed oil and filters every 25 hrs. and threw plugs in once a season. Period!!! Had chillers and boost upped to 7.5 lbs. and CMI Elbow Tops from day one, they never let me down!!! Sold the boat two seasons ago and they are still running strong. New owner had them checked out and dynoed them at 638 HP and was told by his engine guy to leave them alone and just run them, no issues whatsoever. Would trade my HP 500's for a pair any day. Hot Rod Mag wrote them up some years ago as the best, most reliable blower set up ever!!!
RaggedEdge is offline
Old 05-10-2006, 02:10 PM
Airpacker's Avatar
The motors are great, the blowers on the other hand are not real good pieces. Check the oil resevoirs for over full( fuel) or under full( seal gone). Seen several that way. Drop the belt and shake the pulley back and forth. If they have been low on oil for any period, the imput shaft splines wear away and you can hear the play in the shaft to driven gear coupling. The Blower shop has a kit with shaft, seals,gaskets, bearings and drive coupler for fair $
Airpacker is offline
Old 05-10-2006, 05:15 PM
glassdave's Avatar
thanks again guys. Airpacker do you have a part number for that kit by any chance?
Quick Reply: merc 525SC's
