Gen 4 cooling
Originally Posted by GOODT
yes, more then likely it is
Nordic95
Originally Posted by nordic95
Hey guys,
I just noticed looking at pictures of my old motors that I did remove the 1/2 bypass hose that goes from the top of the water pump to the old thermostat housing.
Nordic95
Nordic95
You mean to the intake right? Ive never tried to run without one. Your intake doesnt have a bypass port in it?
Nordic95
can you email me pics of your setup????? just doesnt sound right, this is basicly how it should be set up
Here is a pic of the engines.
I think the problem is the bypass but if you give me a call tomorrow Ill give you some other ideas to try, are you running a dry joint between the manifold and riser???? ( solid gasket, no holes )
Originally Posted by tggrounds
Those engines look sweat. Could one of your temp gages be off ?
