Turbolator Plate
32' SUNSATION
Re: Turbolator Plate
Originally Posted by Wild Card 09
If you look at a section through the pipes you will see that the inner diameter of the elbows is only fractionally larger than the hole in the plate. Donīt bother!
the Flightmaster
Wow, youīre absolutely right. There is quite a difference in diameter! I missed that!
It didnīt make a difference to the performance, though. However, if a 496 is already running at a max around 5000 revs, maybe it needs more than a little extra gas flow to free up more horses at the top end. 496īs tend to produce their best speed figures a tad below 5000 revs.
32' SUNSATION
