Help! water in my drive oil
Hi guys,
I just sent one of myTRS drives to the shop to have a few items replaced oil seal, bearings, thrust ring,shims etc. This drive sucked water into the lube last season and maybe these parts being replaced will cure the problem (there was also some side to side play that needed attention) I've noticed two other things: the drain plug didn't have a correct washer on it (I'm hoping that's the problem) and I'm wondering if the check valve that feeds the oil from the reservoir could be the culprit in blowing water into the drive oil. Your thoughts would be appreciated. Jeff
Re: Help! water in my drive oil
real simple get them to press test and vacum test the drive and that will tell all anything we say here is only a guess, if your already getting it resealed then why ask our opinion?????
the reason I was asking here is that I'm unsure about what role the receptor portion of the check valve assembly might play in providing water entrance into the gear oil; do you have any experiences relating to this item?, thanks- Jeff
Velocity Tom
07-16-2003 10:13 AM
Waterfoul
04-17-2003 08:01 PM
