3M 4200 or 5200 to mount swim platform
Re: 3M 4200 or 5200 to mount swim platform
4200 or 5200 will work as will silicone does well the important thing is good fasteners and correct sized holes so the fasteners don't work under laod, the 5200 can be gotten loose with DeBond a bit messy though.
Phil
Phil
I recommend 4200. It is safe for under waterline applications and will not remove th gel, fiberglass, wood, resin etc..if you need to pull the platform ever.
I would use the 4200, actually I did when I mounted my swim platform. same sealing as 5200, but about 50% of the adhesive properties.
