Engine Pre-lubers
Looking for info pertaining to engine pre-lubers. I have a single 525 and I would like to know if anyone here as installed one on their motor/s. If so , are you happy with the brand that you have and how was the install? Any info would be very helpful.
Thanks,
Eugene
"itilldo"
Thanks,
Eugene
"itilldo"
I installed the Eickert kit on my motors a couple years ago. It's basically a check valve and Moroso fuel pump with high pressure hose and fittings. The suction side plumbs into the oil pan drain valve. You will need a momentary switch to energize the pump. The install takes a little work. I put a quick disconnect fitting in mine. I put another fitting on a ten foot long piece of hose and use it to pump the oil out of the pan for oil changes. Works great.
I believe Monstaaa and I install the same brand, I use Master Lube. There nice units and easy to use and maintaine. I had custom brackets made because I dont like there way of mounting, but other than that a nice piece.
John S.
John S.
