HP 525 Oil Temp Problem, Again!
Offshore Cowboy
Originally Posted by DRIVEN1
Check out these covers I just had made so the salt does not flow into the engine compartment when the boat is on the lift. Mike
![EEK!](/forums/images/smilies/eek.gif)
Originally Posted by Joe
Seeing the pic's... You might also want to consider getting a cockpit cover!
Offshore Cowboy
The boat normally has a cockpit cover on it. I took it off for the day. Since I can not run the boat right now, I figured why not spend a couple of hours polishing the headers on the other two motors and bow rails. I will probably wax the boat this weekend if I get real bored. Mike
I look fwd. to meeting you in Nov. --- presuming you're going to KW, right?
I was just giving you a hard time. I completely understand.... Down here we have this thing called a Winter Season. You wouldn't believe what I find to tinker on in the offseason (when we're not down there).
When is KW? Not sure if I am going yet? If I do I will cruise the boat down there from my house.
Offshore Cowboy
We're still on the fence whether we're registering or running separately (on a diff. day/time than the Poker Run) w/ a few other "local" boats.
Joe
If you're not joking.... www.flpowerboat.com -- check it. You'll want to book a boat slip pretty fast. I'm reserved at the Gallion Marina and Hotel.
Joe
Joe
