small block question heads/cam combo
Re: small block question heads/cam combo
Originally Posted by 245 limited
I agree,not knowing alot about chevys I was trying to keep it simple,I can change cams fairly easy if I remove the seat,I may if someone can tell me what to run!!.
Originally Posted by BajaRunner
Again, I am not anywhere close to a cam expert, just what i have seen and HAD built, I would think about 15 more degrees on intake and exhaust would be closer, especially with the sportsman 2 heads. They flow 200cfm and need a bigger cam.
I plan to play a little more with it,what cam do you have? what are the specs?
Phil
Edit forgot cam specs: RD D @.050 @.200
276 221 134
It degreed at 108 has .510 lift with 1.5 rockers pretty mild probably close to what we used to call a 3/4 race cam, it was ground for a tounament ski boat that anothe fellow was putting together he needed a lot of bottom and mid range to tow 8-12 skiers. It makes just over 65 @WOT and cruise at 40 with very good range, one day it would make a good tender on a yacht.
Phil
I talked to comp cams today,they said to use at least a 218/[email protected] (#12-262-4) maybe a little more lift,I sent a cam request to cam motion today,I will see what they say,I used them when I did a ford 306 and had VERY imporessive results,I hope whatever I do would be worth the time to pull the boat and bring it home for a week to do a cam swap and get it back in by the next Fri.!!!
