How long to wait on 5200 before use.
I need to know how long I have to wait to introduce 5200 to water after using it. Does it need a certain amount of set time prior to use? Can I just wait a couple of hours and run with it?
Buck
Buck
Re: How long to wait on 5200 before use.
Buck
Buck
Buck
Buck
If you want to put it in the water right away I believe you want 4200. Boat Life is also good it will cure if wet.
Buck
Buck
if you used it to glue your wig to your head I would wait at least two hours before swimming, and if you glued your strapon back together you dont need to wait, short stroking it wont break the glue.
