No Start, Slave solenoid?
Jerry B
1993 502 EFI. No click at all from the starter several times I turned the ignition switch.The engine hatch was closed so I couldnt hear if the slave solenoid was trying to work. After several attempts the engine started. No problem the rest of the day. I had to replace one of the trim tab solenoids week before last because the up position would not work. Question is, Where is the slave solenoid exactly and is it the same part as the trim and tab solenoids. I beleive this is the problem.
Thanks for the help.
Jerry.
Jerry.
Mine just went. Sometimes would start, sometimes not. Then not at all. Somehow it got cracked and moisture got in. Was supposed to be new last yr.
Originally Posted by wrenchman
Are they not usually on the starboard side?
Phil
