What can you tell me about this small block?
My new Sutphen has twin small blocks that I know little about. The seller (second owner) told me the engines had not ever been apart, but there's enough aftermarket stuff going on to tell me otherwise. See pic.
Re: What can you tell me about this small block?
From what I can see, as a NON-MECHANIC...
There's a little metal tag on the motor "Mercruiser 350 Magnum" with some 8 digit numbers. What is this about? Can't be from 1991?
There's an Edlebrock intake manifold.
There's a blue gasket below the manifold.
There's a 1.5" spacer betwee the carb and the intake manifold.
There's a Quadrajet Rochester carb.
What range of horspower should I be in if there's a medium cam in there?
Without opening up the motor, does all this speed equipment suggest I need to run top grade fuel?
Thoughts, comments welcome as I try to unravel this boats build...
Also, is the off-color patch on the GIL exhaust from overheating? Is that aluminum? Is this gonna be a problem running in the salt? Thanks
I run Gil aluminum headers in salt third year I had them apart saw no signs of corrosion seem to be just fine Gil says 10-12 years if flushed, though I run closed cooling I still faithfully flush. The engine questions can be answered by a good HiPerf shop, a dial indicator, a degree wheel and checking cylinder volume can give some pretty good answers. HP can be checked pretty close with a prop shaft dyno, they can more then likely give you an idea on the fuel requirements.
Phil
Phil
