525SC mkIV?
Charter Member #737
Originally Posted by badluck
What was the first year of 525SC? Did they start as mk IV?
MarineKinetics
badluck,
1991 was the transition year from the MK IV to the Gen V platform. There are a number of ways to verify this externally. The easiest is to check for a mechanical fuel pump boss as it was eliminated in the Gen V block.
Bob
Bob
Originally Posted by rmbuilder
badluck,
Bob
Bob
Also,
BAM's look up : http://www.mercruiserparts.com/selec...asp?type_id=8H
Shows first series 525SC's being available in 91-92 with Mark IV (two piece rear seal/block mounted fuel pump)
However - some later 92's went to Gen V (one piece rear seal/sea water pump mounted mechanical fuel pump)
And then continued into the Gen VI series later on.
