Mocal Oil Thermostat
This is what I have. I bored out all of my fittings, put a radius on all sharp corners and and cleaned up all the casting flash and marks. ALso I am not running hose barbs, I have -AN fittings.
http://www.jegs.com/i/JEGS-Performan...ductId=1032937
You are going to run temperature gauges?
I would like to add a temp gauge. I was hoping to find one that comes close to matching my OE VDO gauges, because new gauges aren't in the budget for a while after throwing all this coin at the engine. What kind of oil temps are you seeing with that setup? Any leaks or other issues?
t500hps
07-17-2012 09:23 AM
