Moorse Controls
Moorse Controls
AFTER SWITCHING TO A HOLLEY 750 I NEED TO ADJUST MY THROTTLE. WOT NOW IS HALF THROTTLE. EVEN THOUGH IT IS AT WIDE OPEN I WOULD LIKE FOR MY THROTTLE TO GO ALL THE WAY FORWARD. CAN ANYONE HELP ME WITH THIS.
THANKS IN ADVANCE PATRICK.
Re: Moorse Controls
Is your cable hooked to the real big hole on the Holley's linkage arm or one of the smaller holes ?
If not on the big hole you should change to this and it will give you much more travel.
Re: Moorse Controls
Does you shifter have multiple connections for the cable ? If it does, then moving it to one with less 'throw' will give you further action.
Lastly - If shifter has a positive stop, I'd adjust this so your shifter will stop when carb is at WOT. If not, the carb linkage will wear (bend,etc) if that is stopping movement.
Sorry, hard to type thoughts.
