Procharger M3
Procharger M3
Any one here running the m3's .If so have they been reliable.I know that the m1's are good units. When the m3 's came out the had problems with the seals blowing out.
Lakeside Restorations.com
Commercial Member
Re: Procharger M3
good units.. Im probably not far from you in PA.. call me if you would like to know more. We are an authorized distributor & installer for them.. . Jamie / Lakeside
570-639-2628
570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Re: Procharger M3
Artic Friends How Pounds Of Boost Do You Run At ,what Fuel Presure
Re: Procharger M3
9-10 psi of boost,70 psi fuel pressure with 63 lb injectors. I spoke too soon about the procharger,bearing went yesterday allowing impellor to grind into casing,my own fault though. I called procharger over winter and asked if I should be thinking about new bearings/getting unit rebuilt and they said it should easily run another 100 hours,should have had it done anyways,Smitty
