Revolution Marine - 240lb wieght savings!
Racer
Racer
Re: Revolution Marine - 240lb wieght savings!
Originally Posted by pullmytrigger
1989 29 Fountain......twin stock 270hp smallblocks
When you get your GPS working and have the final results I would appreciate a ton if you post them. I was thinking about adding a set on my 350/300hp twin-engine scarab. I would really like to see the final numbers but just the weight savings alone is reason enough to buy them.
Doug,
Firing it up this week and going out this weekend. I'll let you know if it goes boom!
Phil
Phil
Originally Posted by ghittner
I would be really interested in your results as I've carefully looked at the RM design and it seems to me that it is no comparison to the high flow manifolds such as Stainless Marine, KE, Eddie, Gil or any of the true flowing manifolds.
was installing my two sets of Rev Marine aluminum smallblock manifolds today from the stock Merc......One Rev Marine manifold and riser wieghed 25lbs......times four equals 100lbs total........One stock Merc cast iron manifold and riser wieghed 85lbs!!......times four equals 340lbs total for a total wieght savings of 240lbs off the back of the boat......wow!.....way to go Revolution Marine!!
now for a water test.....I'll keep ya posted
Ginger or Mary Ann?
"Not to ruffle anyones feathers" but this is the cutaway of a Revolution sbc manifold.
Still waiting on results from the speed runs. Theres a lot of us SBC guys looking for more and inexpensive power, so how about sharing the results?
