Interrupt switch part number
never seen a normally closed they are normally open then close to complete a ground circut thus grounding coil
they no longer make the old style with the arm you have to buy the new style with new actuator lever
The normally closed switch is used on EFI models with the Delco EST distributor. It opens the IC circuit instead of grounding the coil (points) or ignition sensor (Tbolt).
I believe the part number is 808009A1.
Joe is correct, you have to buy the whole shift bracket if you are replacing an older unit.
Dave
Dave
