Can you use high temp.....
Originally Posted by Daryle Steiner
You Really Need To Use The Gaskets Along With The Sealer. We Have Them In Stock Just Holler
callthem and get correct gasket not worth the outcome ( a motor ) if not done correctly
Geronimo36
I used the Hi-Temp gasket material from Napa for over 8 years and no problems. Just cut a square out, lay it on top of the manifold, rub the plastic part of your screwdriver to make an impression on the gasket material and use a carpet knife to cut it out. I also used Red RTV when putting it together.
I'm sure the gaskets directly from Stainless would be best. If you can get them do it.
![Cool](/forums/images/smilies/cool.gif)
1 Post
Is the red RTV recomended with the gasket ?
depending on the type of gasket material ( merc gaskets have a silver coating on them that does not like any sealer ) I like to use aviation permatex because it penetrates the gasket a little and makes for a great seal
Geronimo36
Originally Posted by articfriends
As far as "losing a motor" no water passes thru any of their connections so are you maybe thinking it might leak so bad it will get cold engine compt air sucking back into motor and creating detonation or something,Smitty
1 Post
The Red Rtv Will Work Fine.if You Are Having A Problem With The Manifold To Riser Leaking Call Me This Should Not Happen And Will Cause Reversion
Tell brownie the jet boat risers came out mint. We fired it up Sunday afternoon & idle @ 1800 rpm for 30 minutes. Snapped the throttle a few times and shook the house & the neighbors came to "visit".
