gear lube resevoir leak
any idea what can be happening? Resevoir slowly looses lube into bilge. I can't see behind the motor but can see it drool down the inside of the transom looking under the motor. line from resevoir is clean to transom plate.
Re: gear lube resevoir leak
depending on the year there is either a plastic pinch clamp there or A quick connect at the transom or may not be the line at all could be the drive leaking into the bellows then into the boat
