bravo 1 slipping while planning off >
Old 07-17-2006, 10:25 AM
GOODT's Avatar
Default Re: bravo 1 slipping while planning off
an engine coupler is made pretty much the same way a prop is with a rubber hub pressed in and yes it will slip as they start to go much as a clutch slips in a car or a prop hub will slip
have seen it many many times
GOODT is offline
Old 07-17-2006, 10:01 PM
pkspx's Avatar
Update
Took the boat out of the water and removed the prop. We noticed the prop wasn't tight tight but it was secure. Put it back in the water, WOT no problems. My first thought was, WTF!? LOL! What should I do now?
pkspx is offline
Old 07-17-2006, 11:09 PM
Received 1,938 Likes on 976 Posts
Drive it till it breaks
Griff is offline
Old 07-18-2006, 06:47 AM
GOODT's Avatar
what he said
GOODT is offline
Old 07-18-2006, 08:02 AM
pkspx's Avatar
yessssssssssssssss
LOL
I plan on it now.
pkspx is offline
Old 07-18-2006, 08:11 AM
mats's Avatar
One possibility, speaking from own experience , the prop may spin out when you come off plane because the drive is still trimmed out for high speed. I my case I thought the drive was shot but it was only the prop ventilating because of the high trim.
mats is offline
Old 07-18-2006, 12:02 PM
pkspx's Avatar
One thing I was told it might be is Clutch cone in the outdrive. Any comments?
pkspx is offline
Old 07-18-2006, 01:23 PM
offthefront's Avatar
Originally Posted by pkspx
Update
I think you should still replace the coupler just to make sure ....
offthefront is offline
Old 07-18-2006, 04:15 PM
It wouldn't slip like you described. It would either go into gear or it wouldn't.
Griff is offline
Old 07-18-2006, 07:01 PM
mats's Avatar
Check the vetilation / trim possibility before doing some expensive repairs. Mechanical failures are very seldom intermittant.
mats is offline
Quick Reply: bravo 1 slipping while planning off
