where to install a boost preasure gauge >
Old 07-23-2006, 03:14 PM
Default Re: where to install a boost preasure gauge
Originally Posted by Scarab28
Guage in trhe dash - we all agree. Vacuum to the intake. Now where does the fuel pressure regulator line come from?
Intake manifold as well. Anything that has to do with tuning (be it map sensor, fuel pressure regulator, etc.) should always see the same pressure thats going directly into the motor.
If you're taping into a 3/8" port then a T between the gauge and regulator will be fine.
roguegts is offline
Old 07-23-2006, 10:03 PM
Turbojack's Avatar
I take it this is a efi engine. With a efi engine (not throttle body) you will want to get your boost and regulator from the intake. If this is carb engine you will want to get the regulator from the carb box and the boost gauge from the intake. Thus the boost gauge will always go to the intake.
Turbojack is offline
TopTrim
12
05-01-2007 06:52 PM
Buddy OO
1
02-23-2007 03:29 AM
eliminatethis
3
09-29-2006 11:40 PM
NEVRENUFF
15
07-02-2002 02:05 PM
klmken
6
07-01-2002 11:02 AM
Quick Reply: where to install a boost preasure gauge
