Water in on Sticks Again! Ideas?
Originally Posted by Rebel_Heart
Thanks for the post on reversion - waterbum. It was mentioned that using this cam with my Dart Pro Ones may create a problem? How would this be different than using the iron heads? The gaskets have also been ear marked as potential problems. How do we find what is actually the problem? Or, do we just keep changing things until the problem goes away? This might be a long and expensive process!
Thanks again for your input. It is appreciated.
The exhaust flow for an iron GM head is about 200cfm at .6 lift. My Valako worked AFR's flow about 300cfm at .6 lift. My guess is that reversion is worse because the exhaust is flowing backwards easier as well. As far as solving these nagging problems, some people learn to do the work themselves, some people pay lots of money for the top notch builders and mechs. that stand behind their work, and others stick to stock Mercruiser power because of it's reputation for reliability. Good luck with fixing your problem.
What are you seeing as far as oil and water temps?
I had a little milk on the sticks from running too cold up here on Lake Michigan.
The water temp on Lake Ozark is now about 87 degrees. My oil temps are running a little on the cold side, but then again, I've never had it running long enough to get them up.
Just spoke with the engine builder. He had run an air compression test with 16lbs and did find the copper gaskets leaking. He said that they were definitely leaking. Now, he is looking for gaskets that will seal. He, also, said that there was a wire used with the copper gaskets that had to be considered when sealing it up? Does anyone have any suggestions? I asked whether this wire could come out, but evidentally that would entail quite a bit of work. I am looking for seals that would work. Thanks.
Originally Posted by JCPERF
Pull the intake manifold off it and replace the gaskets.Excessive water pressure will push out the intake gaskets.
Ditto on JC's comment. I have a naturally aspirated 496 (454 4.250 stroke) with aluminum Brodix BB-2's on it. First time started, engine was perfect, however on the first water test, I pulled the dipstick and not much of a change in level, but oil was chocolate milk. Went home pulled the thermostat out,put in a moroso restrictor in thermostat housing , changed oil, and started on hose... no water in oil, problem fixed, or so I thought..... next water test yielded yet another chocolate shake. Now I'm pi$$ed. Take it home, off comes the intake, and what do I see but clean water sitting on top of lifter galley splash pan. I immediately replaced intake gaskets and also heli-coiled all intake bolt holes in heads. Took the damn thing back to the lake and ran the snot out of it with no problems afterward. Seems the high water pressure took it's toll on intake gaskets near the back water passages, and all that was needed was a decrease in pressure, and some new gaskets. I would also highly recommend heli-coiling your intake bolt holes on heads, at least the ones directly surrounding the water crossovers and passages.
Had similar problems, I found studing with Cometic gaskets to be the resolve. The 3 layer gasket allows for some slippage between the block and heads thus eliminating the gasket problem. It worked for me.
Cometic gaskets. Are they the best? Will they fit with the wire that was placed in the heads because of the copper gaskets used? I am not sure why a wire was placed in the first place, but as I understand it would be difficult to remove.
You say a wire? I guess you mean the motor is O-ringed. Good question. I still think this will fix it for you. Any other thoughts? Any builders?
As far as head gaskets,any decent head gasket will be fine once you get block flat again,I run felpro marine gaskets with 10-12psi of boost on my blown 540 and have NEVER had a head gasket issue,Smitty
I have also been told not to use copper gaskets on a marine motor. I have heard that the Fel-Pro will work, however I took out two sets before the Cometics in one season. I have about 200 hours on the current set with no milk!!!
