procharger problems
I have a 7.4 mpi 310 HP with a M1 procharger tried it at the lake for the first time today with the install of the procharger the boat idled fine but had no power wouldnt go over 3000 rpm and oil was comming out of the dip stick tube so i loaded it back on the trailer and looking for answers oil preasure was fineprop was a 25 4 blade plugs set at .45
![Frown](/forums/images/smilies/frown.gif)
Hi
I have read about this problem several times on the web regarding that motor with the exact same issues which is the same as my engine. I beleive you are having blow by oil issues but the reason why it can't rev past 3000rpm amazes me....
I do know that if you do a search this forum has threads regarding similar issues of oil coming out of the dipstick. I watch this thread with much interest.
regards,
Richard
regards,
Richard
Where do you have your PCV hooked up? If it is on the boost side of the supercharger it will blow the dipstick out in a hurry! It has to be at the supercharger intake.
Originally Posted by snake plissken
I have a 7.4 mpi 310 HP with a M1 procharger tried it at the lake for the first time today with the install of the procharger the boat idled fine but had no power wouldnt go over 3000 rpm and oil was comming out of the dip stick tube so i loaded it back on the trailer and looking for answers oil preasure was fineprop was a 25 4 blade plugs set at .45 ![Frown](/forums/images/smilies/frown.gif)
![Wink](/forums/images/icons/icon12.gif)
If your cylinders are in good shape with good compression and leakdowns, then I think Blowncrown has hit the nail on the head, you are probably putting boost pressure into your existing PCV system routing. re-route it to the air intake side of the supercharger.
Ray @ Raylar
Ray @ Raylar
I have a Jacobs ignition had it on even before i installed the procharger hmmm as far as the pcv i need to go and look my motor is 1999 model mpi and im sure it wasnt ever moved from stock location .i even have red line full synthetic doesnt really matter i guess could it be the oil cooler on back wards or something of that nature..
![EEK!](/forums/images/smilies/eek.gif)
chevalcabre
American Offshore
9
06-16-2008 08:09 PM
