Oil Pressure Problems >
Old 07-25-2006, 09:58 PM
Default Oil Pressure Problems
I'm running twin 525SC, in 35 ft. fountain, when stbr. oil gauge drops to 5-10 psi, but engine still performing great. after 20 min. gauge is back up to 40-50 psi. 2 weeks later port side does same thing. HELP!
BAYVILLAS is offline
Old 07-25-2006, 11:19 PM
FOUNTAINATLAST's Avatar
Default Re: Oil Pressure Problems
I'd check your oil sending units and wiring. Maybe tap in a mechanical gauge to verify the pressures on each engine see what ya got...
FOUNTAINATLAST is offline
Old 07-26-2006, 11:10 PM
Revd Up's Avatar
I was having a similar problem. Hooked up a mechanical oil pressure guage to make sure that I wasn't having pressure problems. My problem was the wire to the sender was a push on connector. I just crimped it a little tighter and problem was solved
Revd Up is offline
articfriends
191
04-29-2021 04:58 PM
tjsmk8
11
05-28-2007 09:40 AM
Revd Up
6
07-06-2006 11:32 PM
FOUNTAINFAMILY
6
10-25-2005 06:27 PM
CayFomula
5
04-14-2004 07:44 PM
Quick Reply: Oil Pressure Problems
