baja 342 mag 502s help
by u boy no worries ,getting desperate here!
payton the engine thats gotthe inlet manifold pressure was low on compression in one cylinder ,had the top stripped on that one it had dropped a valve ,the mechanics re ground the valves skimmed the heads and re fixed it , said it was all now good on compression , now ive got trouble with the inlet manifold, done a temp repair on it for now, it runs ok but still not pulling the revs of the other motor, just wonder if ive done permanant damage now to this motor, with water going in etc , cant understand why they didnt see the inlet manifold when they stripped it down in the winter!
