High flow non-bypass oil filter
Does anyone know of a super high flow, non bypass oil filter that fits a HP6 mount?
Canton's filters seem not to have this application.
Why would you want a "non bypass" oil filter? HP6's have a bypass so that the bearings aren't starved for oil. When the oil is cold and thick... or when the engine is at high revs.... you can NOT pass all the oil through the filter matrix. If the oiling system doesn't have a built in bypass you are going to starve the engine for oil. That little bypass in the bottom of the filter and properly plumbing your oiling system are very important.
Playing with the idea of using accusumps. They recommend a non bypass filter to make absolutely certain no contaminates (particulate) get through.
