What spark plug for a 355 inch in my wellcraft
Hey guys, I replaced the tired 200hp 305 with a 355 inch aluminum headed motor I built. Is there a consensus on which plug to start with? Motor is as follows
355 inch
9.4:1
Ported edelbrock rpm heads
custom ground hydraulic flat cam
performer rpm intake
600 edelbrock carb
355 inch
9.4:1
600 edelbrock carb
you should be ok with a AC mr43t or a NGK br6fs if your still running the thunder bolt ign....
do not run CHAMPION plugs
OK perfect, I am running the stock ignition and was told by another person to run that NGK plug. Thanks
