502s baja342help
When you posted last thread you thought you had 28's,it doesn't really matter,what you need to do is try a set of 23's then a set of 24's if your rpm's are too high,Smitty
smitty yep ive mucked up there 26s on the boat,gonna try a set of 24s but reckon there to small,found out the boat was supplied with 26s past owner saw 70 out of it im sure it could be mechanical
Charter Member #927
Are your thottles going all the way open?
I had a similar problem after I did a winter tune up and had 2 of the plug wires crossed.
