496 Heat Exchanger End Caps >
Old 08-09-2006, 09:19 PM
Default 496 Heat Exchanger End Caps
On a 496 heat exchanger can the rubber seals for the end caps be reused a second time? I am thinking of cleaning mine, but I want to have the seals before I do it if they are needed.
turnerrd is offline
Old 08-09-2006, 10:24 PM
Pwrbt33's Avatar
Default Re: 496 Heat Exchanger End Caps
Yes they can be re-used. Just try to line up the lines in the rubber.
John S.
Pwrbt33 is offline
Old 08-10-2006, 09:26 AM
Chris288's Avatar
so the end-caps are removeable ?????
Chris288 is offline
Old 08-10-2006, 08:22 PM
Chris,
here you go
turnerrd is offline
Old 08-11-2006, 08:54 AM
boatfreak's Avatar
I have had mine apart 3 or 4 times and there are still the original seals. I do have a spare set of them in my boat just in case.
boatfreak is offline
Old 08-11-2006, 09:54 PM
How Much Coolant do you loose when you open them?
turnerrd is offline
Old 08-11-2006, 10:26 PM
turnerrd ,
You are not going to loose any coolant,the caps are sea water side(or lake water).If your boat is in the water don't remove end caps unless you have a way to close incoming water.
ccnhra is offline
Old 08-12-2006, 11:02 PM
Duh,
One of those ones I should have thought about before hitting Submit Reply. Guess i need to go to bed earlier.
turnerrd is offline
Old 08-13-2006, 11:15 AM
GOODT's Avatar
I agree with pwb33 they can be reuse with no problems ( have many times ) just try to line them up as they came off
GOODT is offline
Old 08-21-2006, 02:12 PM
Semper Fi's Avatar
Just don't let this guy GOODT (Joe Heller) work on your boat. He is a dirtbag and still owes me $1,000.00
Semper Fi is offline
UNSANE
06-27-2007 09:18 AM
troc
3
07-26-2006 11:12 AM
ZP\'d
2
06-27-2006 01:40 PM
raynman
3
05-13-2006 07:23 PM
terrygar
2
06-16-2003 03:41 PM
Quick Reply: 496 Heat Exchanger End Caps
